Sweet!!
Sweet!!
Looks great!
What turbo comes with the kit. Also, what problems did you run into. I was thinking on doing a turbo soon.
Its a 70mm that they have made, truthfully im not sure of the brand. The box says newpower on it. Only problems I've ran into so far is the bolts supplied to bolt the turbo to the header flange were too big to fit through the turbo so I had to drill the holes a little bigger. Other problem is the sway bar hits the crossover pipe coming from the driver side header when the suspension is fully extended, it clears though when the suspension is loaded. I was just thinking about grinding a bit off the swaybar.
That looks good, real good.
Nick
Looks awesome Bryon!
Thanks guys
Wow! That's going to be bad!
That will be fun.
Looks sick, should be a fun improvement when done!
