how much does he want for this front stuff ?
Is that just for you ? Cuz I wouldn't mind picking that up
Thats if I pulled the stuff. I work with the guy so I can find out if he wants to pull it an sell it tho.
I have Lincoln rotors on my 90GT with Anny wheels and a centercap. All you need to do to get that cap to fit is grind a bevel on the hub. Takes about 30 minutes to do both sides. You also cant use a dust cap, which realistically isnt a problem. As a precaution, I siliconed the rear of the cap, esentailly making it into a dust cap. No grease has leaked out either...and its been like that for almost 2 years and 8,000 miles.
you can dent it all you want, it still wont fit under the center cap...It didnt even fit with no dust cap. I had to dremel about an 1/8" off the back of the center cap plastic as well to get it to fit with no dust cap
we used some 05 spindles and breaks on a 90 looks badass if you use 17 inch rims
