Whipple snout
Anyone ever rebuild a snout before? I don't know wtf happened! I took the snout off then spun it by hand a few times I can feel a little rough spot in one of the bearings, But IMO not bad enough to make that bolt snap.
http://i861.photobucket.com/albums/a...psfcb9c906.jpg
http://i861.photobucket.com/albums/a...ps6789b7c1.jpg
Ok done, I wouldn't try this at home. You need a press with all the spacers and correct tools like a bearing separator to go with it.
There's a pretty big spring in the center section of the snout for some reason?.?. The snout shaft needs to be pressed out first-from the front-then it will come out/fall out of the rear.This is when you find the big spring. Once you get the shaft pressed out of the snout its all pretty self explanatory.
http://i861.photobucket.com/albums/a...psa3c4d2ca.png
http://i861.photobucket.com/albums/a...ps602ecee1.png
http://i861.photobucket.com/albums/a...psa25dcc1d.jpg
All said and done it took about 45min.
