Arthritis?? Take some Geritol old man!! LOL
Cop car with a corvette engine??
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Did u figure out the actual hi temp issue,had 1 instance where the radiator was too high not allowing enough fluid level and heat soak ,drain system,fill system from the highest point on engine you can untill its full then check level in rad ,and readjust height if needed ,may need to remove the stat! overflow jug height is important also,i think
i think i see awd badge is it?
Temp issue was a 180* stat and the fan kicking on when the defrost is on. In cold temps it never got up to operating temp. Now that it (was) warmer it stays steady at 195-205.
It's not AWD, those are the Safari XT emblems that look similar to the AWD emblems. :)
