Will this main hoop pass,i just bought car and need to fix a few things,cage looks great but never seen main hoop welded to round tube
http://i583.photobucket.com/albums/s...20Pics/sub.jpg
It should, I dont see why it would'nt.
Welding a cage to plate is pretty hack IMO. Also not nearly as strong or safe as being welded to the frame under the car, or to a sub structure like moly tubing under/in the floor.
I think the outrigger welded to that sill plate would need a plate, but not totally sure, because the opposit end is welded to square stock/frame. Unless it passes through to another part of the chassis/tubing.
It has a plate at the sill,its round tube,one side to square,other end welded to plate on sill,hoop is welded in between the to points
